Thread: car stalls out
Old 07-10-2006, 06:49 AM   #1
way2fast
way2fast is on a distinguished road
The engine dosent overheat at all, and i already thought of the cat and chopped it so it cant be that. there are no unnormal noises comming from the engine or tranny. the only thing that came up was a code for the neutral start switch or a/c switch. but after removing a little atf because it was high, and reseting the codes it went away. And I checked the neutral start switch and it is lined up perfectly. Other than that there are no codes stored.
way2fast is offline   Reply With Quote
