Thread: Squeak Problem
Old 07-09-2006, 11:57 PM   #1
theWeezL
theWeezL's Avatar
why cant it be those? replacing the brakes does not make them immune to failure. Also improper installation can lead to premature failure. Its likely an improperly installed wear detector, or one of the shims slipped out of place, and is rubbing on the rotor. I would try to isolate which corner its coming from and take the assembly apart and check it out.
____________
