Old 07-04-2006, 02:23 AM   #3
rnoswal
rnoswal's Avatar
Ohhhhhhhhhhhhhhhhhh................ darn, I was hoping it would take the place of the original o2 sensor and improve on the data and relay it to the fuel management system and run an even better a/f ratio and timing system. I guess if you have the data then maybe you can adjust things somewhere to make it run closer to optimum, but that is what I originally thought the wideband sensor was supposed to do.
DDMCSE, I havent' checked to see how the screw is set. I just put it in and then the plastic deal on top that was originally on the Supra afm. Does adjusting the screw help with anything? Just curious.
Thanks
Russ
