Old 06-26-2006, 03:39 AM   #1
jfunez
jfunez's Avatar
the temp sensor could be at fault.... if its grounded or faulty there is a possibility the PCM is receiving a false coolant temp reading . this reading is very important for fuel delivery, in such case the sensor is really bad it tells the PCM there's a -30 degrees of coolant temp, in that case the pcm will flood the cylinders or run extremely rich.....
