Old 06-22-2006, 09:18 AM   #1
simpsons7s
simpsons7s's Avatar
simpsons7s is on a distinguished road
I am under construction forever because every time I do one project I see ten more that need to be done.... Case in point, I need a front mount IC with hard pipes.
The bumper on pre 89 supras has a row of bolts behind the top grill and turn signals. You have to start by removing the top grill and turn signals . Then place your fingers in the space and feel the metal lip, there are about 8 nuts that face the front of the car that run accross the top of that lip. There are also two bolts near the trim inside the wheel well. If you remove all those all that you have to remember is to remove your fog light wires and you should be able to pull the bumper off. It has been a whils since I did this so if any one else remembers something feel free to post or correct.
simpsons7s is offline   Reply With Quote
