Old 06-20-2006, 10:10 AM   #1
f00g00
Default Injector seals
If you end up removing the injectors change the seals. There are 3 per injector. Over time they will harden so you end up with a too lean condition when they start allowing air to enter. I burned a set of rings for letting them go too long in a lean state. I had codes 25 and 26 pop up now and then and when I had to change motors I had them install a JDM motor so they used my old injectors and it ran so bad because the seals were hard as a rock that it engine just sat there and sputtered and shook. When I set a bottle of water on my engine it looked like an ultrasound bath in the bottle.
Im getting code 25 and 26 again now and am going to change my seals later tonight when its cooled down some.
