Old 06-16-2006, 06:44 AM   #24
f00g00
Thats why exhaust drive (Turbo) or belt drive (supercharger) make so much better sense as they manually go with RPM and then all you have to do is get the fuel air mixture right which could end up costing thousands scince no one makes an aftermarket kit for the NA as far as I know. If your trying to do both electrically then I suggest an engineering degree and a lot of research before attempting it.
It sounds as if your trying to compensate by putting in bigger injectors and hoping the stock ECU will still work, but what happens when your not under boost and the bigger injectors make it too rich?
