Thread: 5spd conversion
Old 06-13-2006, 02:05 PM   #2
Supra2NR
Supra2NR's Avatar
there's a few diffrences from the stock turbo tranny and the stock n/a tranny
As far as transmission choices, you can reuse whatever trans your NA had. The W58 (NA 5 speed) will bolt up to the 7MGTE w/no problems. The NA auto trans is basically the same as the turbo auto trans, just some subtle differences inthe clutch packs, etc. to hold the extra power. If you do have an auto trans you might want to think about rebuilding it or replacing it w/a 5 speed as it will hold only about 300rwhp. The W58 should hold upwards of 400rwhp and the sky is the limit w/the R154.
here's a qoute from one site , i havent heard of anybody discussing 5 spds wit 2jz's so i guess the best i know is the r154 is the closest choice for your 5 spd
so hope this helps you
