Old 06-12-2006, 12:58 AM   #1
Isphius
Isphius's Avatar
you will also need a rebuild kit with all gaskets, bearings and seals, And while ure in there just get the one with the piston rings and replace those while ure at it. Some have options, like oil filter/pump kit, timing belt kit, you should get all of those. Cause they are all things that are easy to change while the motor is out of the car. And dont forget, if its bad, You might need a new crank and/or rod, cause of the bearing grinding away at it after it seized.
