Old 06-11-2006, 03:02 PM   #1
Supra2NR
Supra2NR's Avatar
the brake light warning is a false system its a one time use thing, it dosent matter if it comes on as long as you got your brake lights working i say your good.
and about your dashif its not the fuses maybe its the bulbs itself ,have you tried getting behind it? there's a write up with s.o.g.i. , i only recomend this if your really gonna change the bulbs and not going in there jus for a look cuz its a lot of screws, if you are gonna attempt to open it, i recommend ziplock bags and marker so you can keep em together and you know where the screw came from
if not there's still a solution, i dunt know if you guys have it where you live
my dashlights were too dim so i got those 3 light l.e.d. projectors they're jus 10 bucks works nicely check the pics
ID:	293   Click image for larger version
