Thread: new here
Old 06-09-2006, 04:00 PM   #1
dcrusupra
dcrusupra's Avatar
Originally Posted by Fkatz
hi i am new here so i apologize in advance for the stupid questions
in the process of finding a supra want to do a 2jzgte swap
can only find motors and ecus that are for automatics
what has to be done to convert the ecu to manual?
does the trans bolt right up to the motor or are the motors different?
did some searching read something about a bellhousing is this special ordered or is it the same one that comes on the manual transmission?
and are the wiring harness's really different from the non turbo cars and the 2jzgte
found a 2jzgte non vvt i for 2000 w/ecu and mutilated wiring harness is this good deal?
An auto ECU will work with a manual transmission
The 6 speed bolts right up to the motor and I think you need an R154 bellhousing if you want to use the 5 speed.
What year Supra you want to do this with?
New Rebuild
My CarDomain
