Old 06-07-2006, 09:07 PM   #1
supradaddy0803
supradaddy0803's Avatar
Autozone has a master rebuild kit with pistons gaskets rings bearing and all that jazz but it runs like 700 bucks had to buy one one only reason I know and while you get the motor apart replace the valve guide seals will save heart ache. also make sure you put the head gasket with the this side up, up or you will block the pcv port going through the block thus make a nightmare for yourself mine was marked wrong and beleive me never gonna do that again just look at the two gaskets side by side and make sure they go back on the same way. and if you have any questions I have been and out of a 7MGE 7MGTE and 2JZGTTE they are pretty close in looks when you get them apart except for obvious differences.
