Old 06-03-2006, 01:17 AM   #1
Simann
Simann's Avatar
Simann is on a distinguished road
I admit, the paint is darn good for 18 years old. But it needs to be repainted especially the front bumper (greddy coming soon).
Of course I cannot leave out the "mods list". I have earned every right to post this crap up. Its too depressing not to tell people what I have worked for 2.5 years on. LMAO
SUSPENSION:
Full TEIN RA coilovers $500
SSR Vienna Gluck 17x8/17x9 22+ offset $1000
?? MCD tie rod ends
?? ST Sway bars
ENGINE:
Fully polished engine/ peripheral parts $100
Full teardown and rebuild at 153K miles. Everything is replaced and BRAND NEW. $1500
Lokar custom throttle cable $30
Schneider 272 degree 8mm lift camshafts $250
Comp Cams valve springs part #975 $80
New shims $250
New stainless steel valves $150
3 angle valve job $260
Mild port and polish on head exhaust/intake
HKS MHG $150
Race piston ring set. $80
Clevite 77 bearings $inside rebuild
All studs/bolts in motor are ARP $inside rebuild
Head Torque to 110lbs/ft
Lexan clear timing cover ( supra sport). $inside rebuild
SAMCO coolant lines ( blue) $inside rebuild
Greddy Timing belt ( blue) $inside rebuild
New battery
40K mile old radiator
Oil Filter relocation kit $75
/\ Thats the CURRENT motor inside the car. The new motor is going to be "race ready". Full head work/ custom bottem end.
FUEL SYSTEM:
550cc-720cc injectors $350
Walboro external 255lph pump $125
Sump for fuel tank $60
Custom lines $100
Aeromotive FPR kit $350
CHARGE INDUCTION/TURBO SYSTEM:
Custom T3/T4 ball bearing turbo. 55mm/.70 exhaust housing tange divided $350
Equal Length Tubular stainless manifold $150
4” Exhaust system with Burns stainless muffler $300
HKS 40mm Wastegate with external dump $100
23x12x3 Intercooler/ 2.5” piping/ Silicone couplers $400
Sethron71 Intake Manifold $450
Q45 Throttle Body $80
PROF sheepdog blow off valve. $50
IGNITION:
NGK 3330 plugs
NGK spark plug wires $100
?? HKS Ignition soon???
ELECTRONICS/GAUGES:
HKS FCON with 550cc chip $280
HKS VPC with 550cc chip $200
Apexi SAFC II $150
HKS FCD-K3 $60
ELECTRONICS/GAUGES:
Greddy Profec B spec 2 type S boost controller $150
HKS Turbo Timer type-0 $90
GAUGES:
Oil pressure $25
Oil Temperature $25
Water Temperature $25
Boost pressure $25
EGT?? $110
AEM Eugo wideband meter?? $280
TRANSMISSION:
Stock R154
RPS stage 3- 6 puck sprung ceramic clutch
RPS stage 3 clutch pressure plate (720ft/lbs torque capability) $600
Fidanza aluminum flywheel. $250
Supra Sport 1 piece aluminum drive shaft $450
Clutch stainless steel braided and teflon coated hard line. $60
New clutch master cylinder AND slave cylinder $80
B&M custom short throw shifter $100
SOUND SYSTEM:
Clarion Sterio $Thanks Dad
Boston speakers (4) $Thanks Dad
INTERIOR:
Nardi competition steering wheel. $100
Nardi Hub, genuine hub, not a knock off. $60
Kazama Auto Shift Knob $55
Kazama Auto Drift Knob $0
Levoc Japan Heel Toe Gas pedal $25
35% tint $ Thanks Dad
EXTERIOR:
AUTOPAL H4 housing glass headlights $45
HID ???
New paint/clear coat
Fix dent in rear
New drivers window due to break in.
Pending install:
Roll cage/ Harness bar $400
Veilside pedals $100
Willans or some other 3" harnesses $150
Custom carbon/fiberglass coweld hood< probably this summer.
Battery relocation kit. $150
( i have EVERY SINGLE record from the previos owner which was the ONLY owner of the car....Vanderbuilt UN. Proffesor.)
Simann is offline   Reply With Quote
