Old 06-02-2006, 06:52 PM   #2
MK3_300
MK3_300 is on a distinguished road
I'm sorry, I may have missed it but did you say you've done a (replaceable bulb) H4 conversion? If so then yes you can replace just the bulb, but if not you may still have the OEM style sealed headlights. In that case you will have to replace the entire lens/housing assembly. You can get them anywhere that sells auto headlights. Either style you have, I would recommend replacing them with Silvanya(sp?) Silverstar headlights....much better lighting for only a little more cost.
Also my drivers side high beam dosen't work but my problem was that the high beam positive wire had broke off from the connector. You might want to check your harness wires when you take the headlights out.
MK3_300 is offline   Reply With Quote
