Old 03-16-2005, 06:32 AM   #1
targattgirl
targattgirl is on a distinguished road
yeah make sure the brake switch at the pedal is operating correctly.
I had to fix some cars with the same problem. there's supposed to be a rubber groomet thing that pushes the brake switch when you push on the pedal. sometimes the rubber piece falls off, so make sure when you push the pedal, you are pressing the swich all the way down too.
did you check the basic stuff like your bulbs? check if you are getting power to the bulbs? check the fuse?
targattgirl is offline   Reply With Quote
