Old 05-27-2006, 07:30 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by hobbes
I am currently in the process of buying a 95 N/A Supra with a little under 150k miles. The car on the outside is in great condition. However, I am new to Supras and was wondering if I should be on the look out for any problems that may occur.
Also, I was advised to rebuild the engine before I turbo it. Any thoughts on this? I think its a good idea...
It depends on the compression test results of the engine. If that 95 na mkiv was well-maintained, with synthetic oil and 93 octane fuel for it's life, it may be just fine for a turbo conversion as-is.
You'll find a bit more information on n/a mkiv's here:
http://www.mkiv.com/faq/nafaq.htm
...and a bit more on buying & selling mkiv's here:
http://www.mkiv.com/buy_a_supra/index.html
Life begins at 30psi.
