Old 05-24-2006, 03:09 AM   #1
dcrusupra
dcrusupra's Avatar
Originally Posted by christutecky
Hey, I want my 88 Supra to become a manual trans, so I have been looking into doing a sawp. While I was researching and doing some figures, my mechanic said if Ihave a high milage engine (which I do) Id be stuid not to do a rebuild/swap. So that got me thinking. Can I swap a Twin Turbo 2JZE engine and 6 spd tranny into my 88 Supra? Any info or experiance on this swap?
Thanks for your time
Chris
For the transmission, you will need to bang out the tranny tunnel as well as cut the hole where the shifter comes out of an inch or so because the tranny is a bit longer than the auto. It would take extensive modification on the wiring harness to make everything work correctly. You would also need to bang in the firewall a little. The rear turbo wont fit.
But yes, it is very possible. And there are quite a few guys out there with 2jz MKIIIs. Just need some money.
New Rebuild
My CarDomain
