Old 05-22-2006, 04:13 AM   #1
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
cooleeze was ok, i think a little more thought into it and it would have been a great add on.
the silicone coulings they give are to short and where they connect to the stock innercooler they were to big around. i think they used 2 1/2 inch piping and couplings and the innercooler was 2 inch so it kind of bunched up. the clamps are crappy. the piping barely fit, i really had to work it to make it fit.
they welded all the turns instead of using mandrel bends.
there were to many parts to the kit which would lead to many weak points under high boost. the lower piping was 2 parts and it could have been a one piece pipe if they took a little more care in the development of it.
the upper piping was really nice with the heat treatment. this part of the piping actually fit very well but again the silicone couplings were a little on the short side.
the suction pipe they have doesn't fit very well either and it is also welded to heck and back. they also send 3 little extra rubber hoses to extend the length for the pcv hose and stock bypass valve. it is a very cheap fix and doesn't work very well at all.
i didn't use the 3 extra hose pieces, i actually bought longer hose that would flex and i went with the hks blow off valve so i didn't use the stock bypass valve.
all in all for the money i would go with someone else but if you get it real cheap then it's ok.
djalkyd is offline   Reply With Quote
