Old 05-16-2006, 04:33 AM   #1
mrnickleye
mrnickleye's Avatar
Oil in spark plug holes = valve cover gaskets leaking. NOT the center one, over the spark plugs. It only there to help keep debri out of the holes.
Brakes = DO NOT use those cheap ass pads from the zone. You will be sorry. Your life depends on how well your car stops. Get some good (not necessairly the very top) pads and rotors from Carquest, Napa, etc.
The ABS light comes on in dash when key is first put into 'on' position. No light, no ABS. Also check under hood on passenger's side for a block the size of your hand with several lines coming out. That is tha ABS system.
