Old 05-15-2006, 11:07 AM   #11
Kai
Kai's Avatar
Kai is on a distinguished road
Originally Posted by burton51m
doesnt the antenna go all the way down in the car when you shut off the ingnition? so how could they have broken it off if the motor did work? just wondering?
tony! or anyone elese...what would you use to unscrew the bezel at the base of the antenna because i need to fix mine also.
The motor worked, but the antenna itself was slightly bent, so it never went all the way down and had ended up with surface rust on it.
The bezel at the base, i used circlip pliers and twisted the two lugs anti clockwise until it was loose enough to remove by hand.
Kai is offline   Reply With Quote
