Old 05-14-2006, 04:16 AM   #1
supradaddy0803
supradaddy0803's Avatar
Default just breath it is not as bad as it seems
First the interior depening on how bad it is you can just put it back together. If you need parts just do a google search there are places that make OEM parts but they are expensive try to find one in a junk yard and get the parts you need I have lucked out and found hard to find stuff cheap in a a yard. Second the wiring you are talking about is it the factory alarm or a aftermarket almost all supras came with a horrible factory security system that is way to easy to bypass. I fit is te factory just leave the wiring and zip tie it up and out fo the way mine stoped working correctly so I just unplugged it and no more problems. Also go to a Toyota dealership and buy a shop manual for your car it tells you s lot about internal workings and puting things back together.
