Old 04-27-2006, 02:16 PM   #1
ddmcse
ddmcse's Avatar
definitely a problem if it keeps getting low and/or if it fulls up by itself
empting means it's losing fliud somewhere in the system either you are burning it in the engine or it's leaking .filling up on it's own is another symptom of coolant system problem. i'd start to take serious note of how much water you are using . I drove my supra for several thousand miles with these symptoms and the end result is not good . BHG is what I'm hinting
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
