Thread: White Smoke
Old 04-25-2006, 06:36 AM   #1
mrnickleye
mrnickleye's Avatar
You need to find out if ita coolant thats making the smoke. Coolant coating the 02 sensor will have a negative effect on fuel mixture. Too much coolant in a cylinder can cause hydo-lock, or not allow the fuel mix to fire.
There may other, unrelated problems causing the idle problem.
