Listen to mrnickleye--it will save you a LOT of time and $$$$$!
The turbos have oil squirters to keep the piston tops cooler, and they lowered the CR for the boost. Can you think of WHY Toyota did that?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
