Old 04-18-2006, 10:56 AM   #4
ddmcse
ddmcse's Avatar
it made sense to me to use the stock box .it probably doesn't matter it just eliminates wondering if they are different if you have a problem .
i really wouldn't recommend using the lexus afm with stock injectors .
i'm sure it will work but the question is for how long and if you don't have an a/f meter and you don't get on a school smog dyno every day how will you know if you've slipped into lean .
or at how many lbs does the mixture get too leaned
i guess once you've poured some blood, sweat and tears on the block you have more respect for the car
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
