Old 04-17-2006, 08:59 PM   #1
ddmcse
ddmcse's Avatar
Cool
you remove the wiring (black box)off the lexus afm and put the supra's afm block box onto it .
you'll need to get the 25% larger diameter afm inside the accordin hose that connects to the turbo.
--sounds easy
you really shouldn't add a lexus afm without knowing exactly what you are doing .
you should have an air/fuel gauge installed
you should have larger injectors installed
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
