Old 04-14-2006, 05:11 AM   #2
dcrusupra
dcrusupra's Avatar
It's usually the pump that causes problems like this. Also a clogged injector or 2 could do it. On the next tank of gas, put in some injector cleaner into the tank. And check the spark plug wires and spark plugs. It will be kinda hard to check all the plugs because the intake plenum is in the way. You have to take it off. It doesnt sound like a spark wire or plug problem tho. But it can be if everything else doesnt check out. But unlikely.
New Rebuild
My CarDomain
