Old 04-03-2006, 03:05 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
After I re-lifted the plenum, and seeing how difficult it would be to attempt to reinstall that little 8 mm water hose to the "vertical fitting", I used a long piece of 5/16" fuel tubing and ran it down the side of the block. I used a double-ended barbed metal connector to join the two rubber hoses several inches under the plenum, where it's fairly easy to reach AFTER the plenum is back on.
I now realize that stripping the head bare while in the car was a real dumb thing to do. While I would NEVER do this BHG repair again this way, I'll have to think about how difficult it would be to pull the head with the turbo and intake manifold still on.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
