Old 03-31-2006, 05:09 PM   #1
dcrusupra
dcrusupra's Avatar
The flywheel isnt the same. Its a different bolt pattern. But the clutch and tranny will bolt up without problems. The only reason the flywheel doesnt fit is because it bolts onto the motor not the transmission. So it has a different bolt pattern than a GE. Good luck with it. And if you plan on going past 350HP you might want to consider an R154 transmission.
W58 = 7M-GE 5 speed transmission
R154 = 7M-GTE 5 speed transmission
A340E = Auto tranny for both
New Rebuild
My CarDomain
