Old 03-30-2006, 05:06 PM   #2
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Long time ago I had a Buick-powered Ford. Replaced a leaking water pump with a rebuilt one, and it didn't pump water, period. I just couldn't believe it at first, but even with the t'stat OUT it wouldn't pump water.
Pulled the pump and found that some goon had replaced the impeller with a new one. Problem was the hole for the shaft was a bit oversize--just tight enough to hold it on when inverted.
Just my luck to get THAT one from the auto store----.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
