Old 03-30-2006, 04:06 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Thanks, Tony
The 3rd bolt from the left was for the EGR thing that bolts to the rear of the plenum--has 2 bolts into the plenum and has a 90 deg curved tube that gets screwed onto a fat male thread-like a speedometer-cable connection.
The long bolts were for the lower hidden bolts-intake-to-head. Some fun getting these back in. Trick seems to be to use a small bit of heavy paper in the socket to hold the bolt head fairly tight. Then you try for a while to get the stupid bolt started in a hole you can't see.
Anyway, I managed to get the manifold and plenum back on last night-about 11 PM. Threw away that dumb little metal piece that joins 2 pieces of small rubber tubing for some gadget way under the plenum. I'll just use a single piece of tubing.
Tonight I'll hook up some of the many wires and hoses and start working on the alternator mount/front left lift-hook thing.
Still waiting for my welding/brazing expert friend to fix the turbo oil lines I cut off. Yes, I gave up tryiong to get the bolts out and took 3" thin cut-off blade to them. A few seconds and the turbo came right off. I had planned on using some welded/brazed fittings on them to make future repairs easier, but there aren't going to be any for me after this!
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
