Old 03-29-2006, 07:58 AM   #1
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Yeah had the same problem a while back...Turned out to be the D side switch that went bad and not the P side. After replacing that unit everything works again. THEN most recently the P side wouldn't work and the D side wouldn't work. I too almost gutted out my P side door thinking it was the motor...but what I did was I switched the polarity of the P side switch. The wires running into that harness. Basically switched the negative to positive and the positive to negative. And Voila! The window works...funny thing is that after doing this both the D side and P side switches work, but the P side is ofcourse flip flopped. Down goes up and up goes down. Ionno mess around with that before going out to buy a new D side switch if you haven't already.
Drag0na5h is offline   Reply With Quote
