Center Support Bearing Problem
Has anyone run into this problem?
I have a 87 non-turbo
Went to replace the Center Support Bearing and the Transmission mount.
I bought Anchor brand replacement parts from Autozone.
Upon installation of the transmission mount I realized that the new part did not line up. So i had to order a different brand and install it.
Same thing with the center support bearing. The only problem is..... the brand that made the correct transmission mount does not make a Center Support Bearing. I'm trying to figure out if I order the Duralast Bearing from autozone will it fit?
Has anyone else ran into this problem?
