Old 03-18-2006, 08:18 AM   #3
rnoswal
rnoswal's Avatar
Buy an impact wrench! The breaker bar on the bolt and up against the frame works very well too when you turn it over. Putting a wooden block between a rod journal and the case works well too. But you have to get something the pry with and even a torque wrench set to about 100 lbs should work fine.
Russ
