Old 03-17-2006, 10:03 PM   #1
supra_91
supra_91's Avatar
Originally Posted by sd88supra
i did the math again and it uses up about 3/4 of liter per 420 miles or so. it still seems like a lot, but ill see later if it keeps going down. also, is it very important to keep it full?
there is no milky reside nor smoke, just the normal vapor from the exhaust. and no oil leaks, just the power steering leak from the rack and pinion.
very very important to keep your oil full. it it gets too low you will lock up your engine and then your screwed
