Old 03-10-2006, 05:53 PM   #4
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
It's my wife's car, and the only thing I might do is raise the boost a little with a few washers under the waste-gate actuator. Maybe run up to 9 or 10 lb. max. She doesn't drive it hard, and I'm thinking that the Fel-Pro might seal better because it's softer than a solid metal one.
BTW, do they use a thin sheet of soft copper for the metal HGs, or are they steel?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
