Old 03-08-2006, 03:44 AM   #13
jbrad1
jbrad1 is on a distinguished road
I have a 89 Turbo Auto. i had the same problem is feels like the car is starting of in maybe 3rd gear replace the shift solenoids and fix the problem. i do not remeber exactly which ones was bad. But the solenoid cost me about 115 dollars at the dealer. They use a on off pattern to shift so if they both go bad then it is a fail safe to stay in 3rd gear. It almost felt like you have the e brake on or something its so bad. also you pull it down in first gear manually it dpes better but still didnt seem to have the power it should have./
jbrad1 is offline   Reply With Quote
