Thread: exhaust
Old 02-28-2006, 10:18 PM   #1
mrnickleye
mrnickleye's Avatar
So it is likely an engine misfire problem. could be an intake leak, which dilutes the fuel mixture. Not so noticeable except at idle.
Could be a spark problem. Cap, rotor, wires, plugs. Usually more noticeable under a load (accelerating or mtn uphill.
I'd check/replace these items. They are cheap enough, and new/good ones will help keep you running better.
