Old 02-27-2006, 06:57 AM   #1
midwestmk2
midwestmk2's Avatar
Unless you want to replace the driveshaft with a custom unit just rebuild the W58..The output shaft is different and its roughly about 2 inches longer on the R154..The next weak point will be the rear diff..Ive heard that the hilux diff out of the trucks will bolt strait into our housings you will just have to swap the pinion out also but it would be the ultimate in stength with out just doing a strait axle conversion..
