Old 02-26-2006, 12:32 PM   #1
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
Originally Posted by pwpanas
What was wrong with your current head?
If you're going to continue using the oem twins in sequential mode, you need to get rid of this HKS FCD and purchase a GReddy BCC.
Oh, and why didn't you order the shortblock and head from your local Toyota dealer?
Have you purchased a new gasket set from Toyota yet?
...and you don't need to run head studs (vs oem head bolts) unless you're planning to run a huge turbo & upgraded fuel system in the near future.
The head was destroyed when the block was destroyed. Because of low octane one piston has got a hole in it and it went through the piston and into the block and destroyed it.
The FCD seems to work fine. No fuel cuts anyway.
The shortblock and head costs alot more if I would have bought it from my local Toyota dealer. And yes I?ve purchased a head gasket and all other things I need.
I?m maybe thinking of upgrading to a larger turbo and fuel system in the summer.
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
