Old 02-23-2006, 02:05 AM   #2
mrnickleye
mrnickleye's Avatar
Wink ABS cars should be xtra careful
I have ABS. It works too, cause its come on a few times when I had to stop quick on a bit of a slippery surface.
I pray I never have a problem with it. Diagnosing the fault, and then pinpointing the exact part needed can be very time consuming, and just plain PITA. And possibly very expensive.
I like everything to work as it was designed, but in case I have an ABS problem, and it costs alot to fix, I'll probably unplug it.
The brakes will work like a car that didn't come with ABS, so safety is still good.
