Old 02-21-2006, 04:59 AM   #1
rnoswal
rnoswal's Avatar
Sounds like time to replace the engine. Did it put a hole in the block? Also, and we have had this discussion with others, it is very hard to read your message because of not having any punctuation. We don't need capital letters but periods help a lot when you are changing to a different item.
If it is rattling real loud and running on less than all 6 cylinders, then it is time for a tear down or let someone who knows engines listen to it. Blown engines are blown engines with the same consequences. Probably your oil was low and spun a bearing, then it seized and broke internally. Expensive and very time consuming unless you know where a good used engine is for a decent price.
Let us know how it goes.
Russ
