Old 02-10-2006, 03:50 PM   #1
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
Originally Posted by pwpanas
How did the piston get destroyed? Oem pistons can old 24psi and 550hp easy...even 30psi and 800+rwhp is no problem...but not on pump gas. The most expensive pistons you can get (JUN/Cosworth) won't hold 24psi on pump gas either, because at that boost level & octane you're not burning the fuel, you're DETONATING it. If it's only the piston that's destroyed, put a new oem piston in there (Toyota should quote you a fair price), run race fuel, and you're done.
P.S. I hope your cylinder wall isn't damaged too...
yes I was on pump gas but this car has always been driven on pump gas it?s a daily driven car.
How much Octane do I need to be safe ? here in Iceland you can buy 98 and 99 octane gas at pumps I think in you standard that would be 94-95 octane
How long can the stock pistons handle 20 psi? how many miles?
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
