Thread: Interior
Old 02-05-2006, 11:37 PM   #1
Burn N' Up
Burn N' Up's Avatar
Oh for heavens sake ok
Take out the tonneau, roll up, cover.
Find everything with a little plastic top, about the size of a nickle and pop them all off, everything in the rear and in the rear passenger areas, don't miss the ones on the cieling just forward of the hatch hinges.
You'll also need to unscrew the speaker covers that are perched on the rear towers. You'll need a flat screw driver to pop these tower covers off and lots of other stuff.
You'll need to take the clothing hangers off, and unblot the front and rear seat belt carriers.
Unbolt and remove the rear seat, there are little locking mechanisms under the seats and bolts attaching them from the rear.
Now pop the lower quarter panel trim. Now remove the deck trim. Thats the one in the rear corner of the car. Don't forget to pop off the little access doors and unscrew the one screw thats in there.
Now remove the speaker box, its got some more screws too.
Now Unscrew the quarter glass molding and pop it off, the one in the lower rear corner. Then slide off the upper molding . Now pop the upp joint molding cover. Now to remove the window you need to remove the 4 upper retainers, remove the retainer nuts from the inside and use piano wire to cut through the adhesive. around the window. pull it out and your done. high five.
Hope this elaborates on my statement.
