Old 02-04-2006, 07:43 PM   #5
Isphius
Isphius's Avatar
Originally Posted by mrnickleye
^^^ This is true. But...7mge has 9.2 compression. You can run regular 87 octane under normal conditions, when the outside air temp is below 100*. The knock sensor will let the computer know if your getting any pinging, and it will back down the timing to stop the pinging, which is HP loss.
True, But i know wit my friends camaro, tpi and running 10:1 pistons, on regular gas you never hear a ping or knock or anything, it runs beautiful. its just because the knock sensors and computer are fast/good enough to prevent it. but like you said there is power loss...so it does help to run higher octane if your compression is higher than about 9:1. But my point is (to others) that just because you dont hear the pinging, doesnt mean its not retarding the timing.
