Old 02-02-2006, 11:11 PM   #1
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Originally Posted by Idaho
Hi, I apologiye for mz english, but can you specify Permatex Brake Quiet " ??
I don't know what to udersatnd uder this term..
thanks..
Well the "Permatex Brake Quite" is used to seal up imperfections to decrease the likelyhood of getting a BHG. If you just can't get your block machined, but have determined that the block is straight and not warped without too big of surface imperfections, this may be the way to go.
You would buy the spray can type (it also comes in a tube, but that is not what you want) and put on 2 spray coats on each side.
Spray the gasket while it is hanging so that you can spray both sides evenly that way.
Let dry for about 15 minutes and then start assembling things.
The following is a picture of a can:
I also took a picture of a MHG that had this sealant on it (in the attached pic).
It is not my build up, but is my friend's (shaeff's).
He won't mind me using that pic, since I was the one that took it in the first place. heheh
EDIT:
Didn't know you had already replied, kewlcoconut.
You did it while I was making this post. heheh
TONY! is offline   Reply With Quote
