Thread: turbo
Old 02-02-2006, 01:54 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Veilsidesupra
Hello everybody. I want to install a sigle greddy turbo on my car but i dont know which one is the best of them. I have an automatic 1994 supra twin turbo....
Unfortunately, the best one is probably not a GReddy. The level of turbocharging technology in GReddy turbos is severely out of date. Even the smallest GReddy turbo (the T-78) has tons of lag, and when boost hits, it comes on like a freight train. This usually leads to wheelspin instead of acceleration.
In addition, ALL of the GReddy turbos are too big to run on the stock fuel system, so you'll need to upgrade your fuel system FIRST. Again, the smallest GReddy turbo is a T78, and if you install cams it can put down over 750rwhp through a 6spd (680rwhp through an auto). All of the other GReddy turbos are T88's and they're all good for over 750rwhp through an auto. Again, they're all too big to run unless you upgrade your fuel system first.
Also keep in mind that your oem torque converter's stall is much too low to run with a T78, and your oem auto transmission can only reliably handle about 500rwhp unless you get it 'built'.
What is your horsepower goal (max)?
Life begins at 30psi.
