Old 02-01-2006, 10:25 PM   #1
sboy
sboy is on a distinguished road
Originally Posted by rnoswal
I am not sure about this but when I had low coolant because of a leak, the car would act the same. I am sure mine was because the sensor didn't pick up the warm water and never registered anything but cold. So it started rich and always bogged, hesitated so bad it was very hard to drive. That may be your problem, a cold start sensor going out. Of course that is just my guess and I don't know if a bad sensor like that puts out a code.
Let us know.
Russ
yeah, i think that's my problem. when my engine starts, my rpm was high but i think it is normal for the engine to make the water temperature stable, but for my engine it takes a long time. oftentimes, i have to open the hood and to check the radiator if it is hot enough. what sensor do i have to change? if its the water temp sensor, which one is it? where it is located?
BTW, thank u again guys!
sboy is offline   Reply With Quote
