Old 02-01-2006, 06:23 AM   #1
midwestmk2
midwestmk2's Avatar
Yes maybe,but after you tear it down and see if you need to replace any gaskets,bearings,rings,seals,etc..You will have spent around 1200 or more just to make sure it will be reliable..Not counting on having to change the entire harness and ECU and other misc, stuff to get it going..Sure getting the engine for 450 sounds good but in the long run youll end up paying for it anyway..
