Thread: Voltage
Old 02-01-2006, 01:26 AM   #2
mrnickleye
mrnickleye's Avatar
I would not do the above mentioned 'test' of the alternator. These cars, and most on the road nowadays, have computers. The computers run on 5 volts. A voltage 'spike' can occur if you remove the battery cable while the engine is running. This can 'fry' a circuit in the computer, or weaken it, which may give out while driving. Then you'll have another problem to fix, and it won't be cheap.
Get a volt meter, from radio shack or similar store. You can use it to test the battery voltage, and many other wiring and circuits. It will be a valuable tool to have around. I have 2.
